Old 12-03-2010   #1
France
Guys ive got new gearbox oil leaking out my damaged gearbox exit plug.
Fiat are absolutely useless, where can i get a new gearbox oil exit plug, mine has been previously damaged and i need a new one. Is there anything at halfords to anyones knowledge that will do the trick?
Or can i indeed use the undamaged gearbox inlet plug? its a bit shorter in length but would it work?
Gutted loosing all my new oil!!
Damien.
usedtohaveavaldisere is offline Reply With Quote Quote
Old 12-03-2010   #2
All go, no show
lewey's Avatar
lewey has donated!
Re: Guys ive got new gearbox oil leaking out my damaged gearbox exit plug.
FIAT do have these parts, you just need to give them part numbers. Are we talking the drain plug for the main box of a pre-91 4x4?
If so, the number is 7751645 - 3.73. It's magnetic, so worth getting proper one.
lewey is offline Reply With Quote Quote
Old 12-03-2010   #3
France
Quote Originally Posted by lewey View Post
Thanks Lewey
Went to fiat in hove today guy was friendly but had no clue to the part number etc.
My car is a 1990 sisley so that part number should be ok?
Dont know how i am going to get the old one out the head is split!!
Damien.
Old 12-03-2010   #4
All go, no show
lewey's Avatar
lewey has donated!
That is the part as far as I can tell. Sounds like you might have to drill and tap it.
Old 12-03-2010   #5
France
Cheers Lewey
Going to have another go tomorrow!! got a 14mm gona try and tap it in to try get a prise it out. Wish me luck. Maybe try and use the fill plug to plug the drain hole?
Damien.
Old 13-03-2010   #6
Beware the Panda Face.
purple haze's Avatar
Trader Rating: 3
purple haze has donated!
Saudi Arabia
Hove!!??....close to me then..
If the forum has saved you money or a garage bill why not donate 1 to keep the knowledge coming. You know it makes sense
Quote Originally Posted by Wee Smurf View Post
I don't have a classic Panda but regularly come here. It's much more friendly in the classic section than the nuovo section.
purple haze is offline Reply With Quote Quote
Old 13-03-2010   #7
France
Guys i finally got the damaged gearbox exit plug out!! Bonded a 12mm hex bit onto the plug with liquid metal adhesive and brute force!! what a feeling when the pig came loose!!
Pumped the recaptured oil back in again and job done.
So no more leaking and shiny new plug in its place bliss....
Damien.
You in Brighton purple haze?
(T) leaking gearbox oil fiorinoman Fiorino (Mk1 / Mk2) 10 12-09-2009 14:24
(T) gearbox oil leaking woolfika Bravo / Brava 3 02-09-2009 00:00
(T) Gearbox oil change; drain plug & fill plug? combwork Multipla 3 03-07-2009 10:50
(T) Gearbox Oil Filler Plug JayEm Stilo 8 19-02-2009 10:28
(T) Oil leaking from top of gearbox Brendan W Punto (Mk2/2b) 1 08-12-2008 11:16
