Sorry - I hadn't looked at your location. D'oh!
Anyway, regarding the engine:
exhaust down the front, just behind the radiator - FIRE
exhaust down the back - likely to be a variant of the old 903 pushrod engine (possibly 899cc like the smaller Cinqs).
An ECU is Electronic Control Unit, also known as ECM - Electronic Control Module.
Fitted to nearly all European cars from about 1993, and generally controls fuel injection, and ignition. Although there are some exceptions: my early 1993 Panda has an ECU which is only involved with fuel injection, but it has a distributor which has no points, for example.
The (single point) fuel injection on this Panda looks for all the world like a carburettor ( but has a number of electrical connectors plugged into it), and works in a similar fashion, apart from it's fuel being pulsed into the air flow. The ECU alters the pulse width to change the ammount of fuel delivered.
I'd guess your coils are less than 12 volt rated, not necessarily because of a ballast resistor, but because the electronic switching loses some voltage across the device doing the switching - I think my coil is effectively a 9 or 10 volt coil - but you may be in the right area for a fault on yours if it does have ballast resistors.
From what I remember of ballast resistors, they are bypassed when starting to give a higher voltage to the coil when the battery voltage drops due to the current taken by the starter motor. When they fail you would get a situation where a car would start and run while the starter was engaged, but stop as soon as the starter was released.
Does your Panda seem to start on 4, then run on 2 when you stop cranking?
If so, get looking for ballast resistors!
The idea with twin coils is to do away with the distributor - a mechanical lump, prone to wear and variation between one and the next, resulting in inaccuracy in ignition timing, and more voltage lost across the rotor arm gap than you would through another spark plug.
The timing reference on later Pandas is a toothed wheel mounted on the crankshaft in front of the alternator drive belt.
There is a sensor mounted close to it, known as CAS (Crank Angle Sensor), and the ECU uses this for timing and engine speed information. There is a tooth "missing", which is the reference point.
Regards
John H
