Also make sure the air filter is in reasonable condition, or it will push up the CO reading. Might be worth checking the ignition timing and points as well?
as a rough set up with the engine running at normal temp screw it in slowly until the engine note changes the turn it back out one full turn, this should be ok until you can get it checked properly.
