Help sought again.
Finally got my 4x4 Mot'd and Taxed and on the road, but two problems still persist.
1. Nearly siezed engine driving from Leicester to Nottingham, due to overheating. Ignition / fueling fault - vacumn advance blown, new part ordered. Apart from initial throttle opening should vacumn advance affect running throughout rev range?
2. Knocking from front near side wheel - regular knocking with each revolution of wheel, increases with speed, some vibration felt through floor. Increases slightly turning to right, decreases turning to left. No knocking on full lock, either way. Wheel not buckled, tyre pressures correct and no bulges. Visually everything look perfect. Wheel does not get hot and have replaced discs, pads, calipers, in any case. I'm left thinking must be driveshaft, but as it does not knock on lock am puzzled?
Any help appreciated.
John
NottsCharger
John
NottsCharger
