nrbrowning
I have a 1992 Fiat Dance 903 5 speed. I have two questions here;
A few months ago i ventured to top up the gearbox oil level up. I managed to undo the plug and I expected to have to top up a little oil since it is a closed system. I was surprised to have to top it up significantly before the level was clearly visible and oil was oozing out. I guess the oil had not been topped up before but I was surprised to see how much oil I had to pour in. (no sign of any leak) Any advice/diagnosis? If I wish to drain the gearbox oil and replace it what volume should I expect to drain/refill it with?
2) At high revs and at low speeds the car is less responsive and I think the clutch is slipping. Without replacing the clutch can I do anything to further diagnose/fix this problem? How easy is it/expensive to replace the clutch?
I am still looking for a second hand replacement Windscreen in the London area.
