fiat903
Member
Hi
has anyone experienced this . The engine runs for a few miles then it appears
as if the carb is over choking with petrol and it slowly stops with no responce
from the throttle. You leave it for 2 minutes and it starts perfectley and drives
off normally. I have changed the diaphram on the choke arm (its the weber carb) . i have changed the carb as well now with no result . i have changed the distributor as well now, again with no result.
There is petrol in the float chamber but as i have said it stalls because of excessive fuel. I have fitted a fuel filter but that has made no difference. Has
anyone any idea's . I am now thinking coil break down or the ballast resistor? .
thanks fiat903
thanks fiat903
