the flexi hoses go where the movement is, so because the rear brakes are mounted to a solid axle the brake lines are solid right into the rear cylinders. Follow the brake lines back and the flexi hoses will be where the brake lines leave the rear axle/ driveshaft and join to the bodywork. On the 2x4s the join is at the front end of the omega beam but I'm not up on the 4x4 layout I'm afraid, suspect it'll be toward the front end of the propshaft near the bulkhead to minimise the movement. How's my guesswork 4x4 folks?
Andrew
