General my damn bonnet won't open
microphonehead
glasgow
Anyone got any tips for getting the bonnet open? The cable is connected ok but no matter how hard you pull (I've pulled the cable very hard, with grip pliers too) it won't open.
Haynes suggests using a bit of bent wire to open the lock but doesn't really say which bit of the lock to hook it on to (and you can't see it there anyway)...
Very annoying after buying all the stuff to service it...
bah!!!!
Getting someone to push down on the bonnet at the point the lever is pulled and held out, then try lifting up the bonnet - works on one I still get to see from time to time, and used to work on one now deceased: rust in peace.
Hi, Steve C's solution was the only one that worked for me afore I fitted bonnet-pins.
Good luck.
Microphonehead........HI !
If, after all fails, you cannot open you'r bonnet; give me a call.
Crowbar! Crowbar!
"If it doesnt work the first time, get a bigger hammer"
long time ago now but I got it open(and still get it open) by getting someone to to bounce the front up and down while I pull the release. I'll need to try just lifting it up with my fingers as suggested above, it's a real pain to have to find an accomplice.
