General Panda 4x4 jacking and axle stands
Yak
Huddersfield
Im trying to find where to jack up my panda 4x4 and pop it on some stands so I can have a look at the brakes. Ive ordered in the porter manual but it dosnt mention in ti where to jack the car up with a trolly jack or where to put axle stands.
Any of you guy know where to place these under the car?
Ta
Yak
as a general rule of thumb, you can jack the car up anwherer on the chassis, on the rear suspention arm (not the crossmember - the bit that goes across the width of the car... may not have either of these as it's a 4x4). I can't really help any more than that cos I don't own a panda!
Yak said:
Aye one? Does it sy anything in the Haynes manual about the normal panda?
Only to use a hydraulic jack, and supplement it with axle stands.
No suggestion about where to put them though.
"Porter" is no better.
There is a pad just in front of the front rear spring hanger (does that makes sense) - find the rear spring - find the front of it - and there is a pad just in front of that. I use that. I also use the pad in the centre of the chassis just behind the rear bumper.
At the front I use the mounting points for the sump guard/bullbars.
Hope this helps
