Not really routine but... I replaced the discs and pads both sides and the hub carrier and track rod end on the near side yesterday. Discs and pads have been covered elsewhere so I'll not bore you all with that but I thought I'd share my hub carrier adventures...
Getting the thing off wasn't a problem; undo the two top bolts and knock out with a drift, then crack the balljoint with suitable splitter... Getting it back on was harder than it looked. I tried a number of ways and the most successful solution seemed to be to fit the balljoint into the socket and nip up then bully a bolt into the bottom mounting holes and knock it through. By this time the hub carrier was skewed over and the top holes didn't line up. I put the old hub nut back on to the axle (with the car securely on stands) and jacked the hub upwards until the holes lined up... Big hammer helps too!
Wheels on!! Rusty door...
I've just got to sort the tracking out and kill the hamster that hides in the air box and then I'll be able to get started on Agnes...
Cheers, Luke.
Cheers, Luke.
