Old 09-02-2009   #1
First Panda 4x4 buying advice needed, newbie advice needed!!
Hi All,
I'm new here and hoping you can indulge me with some good advice! )
Having pondered long and hard over the car I would like to get as my first 'classic' I have decided I want a Panda 4x4 (having decided against a classic Skoda or Trabant!!)
My question is a very open one, what I would like is some general advice from those of you in the know about: the different models, best one to get, fair price I should pay, what to look out for, best year, engines, trim, etc. Even any good modifiacations to make?
Many thanks in advance and I hope this will be the start of something fun!!
Ben
BenMK4x4 is offline Reply With Quote Quote
Old 09-02-2009   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
re: First Panda 4x4 buying advice needed, newbie advice needed!!
Hi, Welcome to FF.
Firstly you need to decide what your budget is, as you can be looking at anything between 500 - 1500!
When you say modifications, what did you have in mind?
Jon.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 09-02-2009   #3
Bougainvillea Rosso has donated!
Hello and Welcome,
The only two models you are likely to get in the UK is the standard 4x4 and the Sisley and they have the same engine (unless you get hold of a Mk 1 which is highly unlikely). The engines are generally not too much of a problem. It's the bodywork and gearbox you need to keep an eye on.
Panda CLX 1992 & Panda 4x4 1987
Bougainvillea Rosso is offline Reply With Quote Quote
Old 10-02-2009   #4
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
welcome aboard. Panda's a great choice there by the way, the wife had a Skoda 130 rapid coupe at the same time I had my first Panda. Panda ran flawlessly the whole time we had it, Skoda had an extra battery wired in to get it started, had no second gear until the gearbox warmed up, and went through two cylinder head gaskets before we sold it (with about 50k on the clock) wasn't as 'rapid' as the Panda either.
top tip for buying a Panda: no such thing as 'surface rust'. if you can see rust bubbling on many bits of bodywork, that's coming through from the inside.
Andrew
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 10-02-2009   #5
Beware the Panda Face.
purple haze's Avatar
Trader Rating: 3
purple haze has donated!
Saudi Arabia
I would keep it simple and cheap...buy a nice 2wd panda at first..plenty more available..lots more special editions..and to be honest if your not going off road, more fun to drive..(Rear leafs vs omega)
BTW...Welcome.......kev
If the forum has saved you money or a garage bill why not donate 1 to keep the knowledge coming. You know it makes sense
Quote Originally Posted by Wee Smurf View Post
I don't have a classic Panda but regularly come here. It's much more friendly in the classic section than the nuovo section.
purple haze is offline Reply With Quote Quote
Old 10-02-2009   #6
Hi all, and thanks to the responses so far
I think a little more info on my part is required:
Budget wise, I'd be happy spending around the 1000 or so mark for the right car.
It is a 4x4 Panda that I definately want, not 2WD.
By modifications, I was referring to those that would make it more off-road capable.
I would mainly use the car on-road, but I do want the off-road capability, that's why I chose this car!!
What do you think?
Ben
Old 10-02-2009   #7
Hi Ben, there's not much you can do other than tyres and a home made snorkel unless you're into serious fabrication work. There aren't any aftermarket mods available that I'm aware of. You can get a small increase in lift by making spacers for the shocks, but I doubt whether the effort is worth it, too much and you knacker the u.j.'s . Only bigger diameter tyres will increase the limited ground clearance, and then you can run into problems with wearing through the fuel filler, and losing your mudflaps when reversing.
Mike
xsparky is offline Reply With Quote Quote
Old 10-02-2009   #8
Trader Rating: 3
Saudi Arabia
Quote Originally Posted by xsparky View Post
Mike
They are pretty much good to go and do exactly wot it says on the tin...
kev
Old 10-02-2009   #9
Good to go sounds good to me!!
Mad question, but has anyone fitted a winch to a Panda 4x4?
Also, how about sump guards and other under body protection?
Old 10-02-2009   #10
Trader Rating: 3
Saudi Arabia
Check out photos of members cars thread
Old 10-02-2009   #11
Trader Rating: 2
Quote Originally Posted by BenMK4x4 View Post
Winch, yes, but won't pull anything except the Panda out of trouble. I remember seeing somewhere that Fiat quoted the only way to improve the 4x4's was to fit a winch to pull itself out of any trouble.
Sump guards are standard on all 4x4 Panda's (and has saved mine a few times)
Jon.
Old 10-02-2009   #12
Road Rat Pilot!
default_user's Avatar
Trader Rating: 2
default_user has donated!
You might also consider a Panda 4x4 based kit car like mine. The only ones likely to be available now (I think mine's the last of it's breed) are ones called the Torino by NCF Motors. Another forum member has one. His user name is lesnewell if you want to search for posts by him.
Here's his web site if you want to see what one looks like. They're still pretty rare though so you'd probably have to wait a long time to find one:
http://www.lesnewell.co.uk/Torino/Torino_index.html
The advantages of something like this are that they are much easier to modify if you want to and kit car insurance can work out considerably cheaper than production cars for younger drivers. Plus, it has novelty and rarity and will probably outlast the mechanicals, being built like the Forth Road Bridge.
Welcome to the forum by the way
The Road Rat, or Satans Rodent, is a kit car based on Panda 4x4 mechanical components.
AND IS NO LONGER MINE! : (
default_user is offline Reply With Quote Quote
Old 10-02-2009   #13
Hi Rick,
I think I actually remember seeing that car on ebay about a year or so ago (could be wrong though)!! Interesting... not sure about the looks though!!
As for insurance being cheaper for young drivers I'm hoping that (in this case at least )28 doesn't count as young!!
Old 10-02-2009   #14
Trader Rating: 1
Low miles Sisley in Yorks here:
http://cgi.ebay.co.uk/FIAT-PANDA-SIS...1%7C240%3A1318
Hello, by the way
* * * PANDA 'R' US * * * (aka MARTIN)
2012 FIAT 500 POP
(Previously owned: '00 Sei Sporting, '84 Panda 45, '94 Panda CLX, '96 Cinq SX,'92 Panda MANIA, '86 Uno 45)
Pandarus is offline Reply With Quote Quote
Old 11-02-2009   #15
Road Rat Pilot!
Trader Rating: 2
Quote Quote:
Oh to be that young again.
As for Les's car, I think it was on eBay but didn't sell. Les contacted the owner and made an offer. And if you're worried about looks maybe you shouldn't be considering a Panda anyway...
(G) Advice needed by Panda newbie yknivag Panda (Classic) 19 28-04-2008 20:24
Newbie-Advice on buying a Multipla needed Chris Barlow Newbie Central 2 19-10-2006 17:05
(G) Buying Advice Needed - Please help a tall, skint newbie. Potato Punto (Mk2/2b) 13 30-08-2006 01:18
(G) Buying advice needed DaveP 124 Spider (Classic) 0 28-01-2004 16:31
