John H
Established member
I've been looking afer two Pandas for a while now, and have finally got to the bottom of why the braking effort required is so different between the two (neither of which have a servo).
The one I use as my daily driver had some "Pagid" pads and new disks fitted when I got it, and it stops quite well: you don't need to do your Bruce Lee impressions to stop it, and you can lock the fronts up on a dry surface if push comes to shove.
But the other one (which my daughter crashed the other day, because it wouldn't stop...) has never had the same feel to the brakes, despite lots of cleaning of the sliding bits, and lots of "copper ease" on reassembly.
Today (having got it all straightened, and glued back together again) I thought I'd have another go at the brakes on the daughters Panda and replaced the FIAT pads with some BOSCH ones (£9.99 from A.P.E. in Erdington - cheaper than Halfords own brand), I had wanted the Pagid ones so I could compare like with like, but they were out of stock. Anyway, having got them somewhere near bedded in I reckon the braking effort is now broadly similar between the two. AND a lot better than it was
Moral to the story, if you want to stop a Panda (or have a handbrake that works on a Cinq, from what I gather in the other bits of this forum) you need something grippier than FIAT standard parts.
I understand Pagid is German as of course Bosch is - I think they know about the need to stop [^]
