Old 05-08-2004   #1
E-Brake Light
Hi all,
I have a question about the dash display light for the ebrake. Ever since I got the car the light has been on. I am just now going to try and fix the problem. Is there a sensor on the handle under the floor carpet or is there a wire off some place. This is the only problem I have with this panda. It has to be the best one ever built to be in such good shape with nothing breaking. Thanks for any help.
Nacho
Nacho is offline Reply With Quote Quote
Old 05-08-2004   #2
Portugal
Re: E-Brake Light
There is a switch under the e-brake that activates the light(it´s normal to get worn out, at least mine was), remember that the light may also indicate brake malfunction.
smokeme is offline Reply With Quote Quote
Old 07-08-2004   #3
Don't polish it, DRIVE IT
pandafan has donated!
Re: E-Brake Light
Hi... What usually happens is that, with a lot of use, the handbrke lever bends towards the driver. Eventually it brakes off in your hand (trust me...I know).
However: long before it does so, it registers as ,on' whilst you're driving. To check whether it is simply a misalignment of the handbrake, try pushing the lever towards the passenger seat as you are moving. If the red light goes off there really is probably nothing to worry about for the next 30,000 miles or so.
www.hawortharts.com
pandafan is offline Reply With Quote Quote
Old 07-08-2004   #4
Portugal
Re: E-Brake Light
Hand brake is meant to be pulled up not sideways that why yours broke .I personally have never seen one broken.
Old 08-08-2004   #5
Smile Re: E-Brake Light
Smokey...Yes...I know that's why mine broke!!!!
I'm just trying to be helpful....I may not be the only ham-fisted, 17 stone Panda-driver here y'know!
www.hawortharts.com
Old 08-08-2004   #6
Portugal
Re: E-Brake Light
If the test on the mastercylinder(green button on cap) works then you shouldn´t need to worry about it
Old 10-08-2004   #7
Re: E-Brake Light
Hey all,
I was in the car a yesterday and got to looking at the set up. I can see the little button switch you are talking about. I was pushing it and there was no change in the light. When I was driving I watched the light closely and when I hit a bump (easy to do in Italy) the light would flash off. I believe there may be a loose wire to the switch or something like that. I am going to check it here in the next couple of days. If I get a fix I will post the results. Thanks for the possibilities.
Nacho
(T) Brake bulb warning light anthemmaster Bravo / Brava 10 24-03-2004 03:44
(T) 3 Brake Lines & a ABS Light Q TOY Bravo / Brava 1 13-03-2004 02:43
(G) Brake Light nippsnow Punto (Mk2/2b) 2 19-12-2003 15:16
(G) Brake light problem - help! Surrey Sporting Panda (Classic) 8 01-07-2003 02:23
