Hi Folks. I have a very nice '88 Panda 4x4 Sisley, which has decided it would be a good idea to let water into the driver's footwell.
I can't find a thread answering this, so apologies if it's a common question. Has anyone any ideas exactly where this is likely to be coming from (and how to cure it) please?
The water is mainly dripping from the bottom of the fuses in the footwell (so if the electrics start playing up at least I know where to look!! ). I can't see that the drainage holes under the windscreen (under the 2 plastic grilles) are blocked, but it was a bit cold & wet today to investigate fully! Is there somewhere under there that water collects?
The windscreen rubber doesn't appear to be lifted, but is that another likely candidate?
If it helps the water is dripping in when the car's stood, so it's not a result of ambitious navigating of streams etc.......
Many thanks in advance.
