yellow911turbo
Hey all,
An issue with my car. When I first got it about a week ago the vaccum advance hose was disconnected and plugged with a screw and the car ran a little rough. In neutral when slowing down or waiting at a stop, the car would stall if I didn't have the choke out a little. I plugged the vaccum advance into the distributor and it sounded better especially when revving up as is the reason for the vaccum advance. We also tried to adjust the carburator hoping that adjusting the mixture would fix the problem. The screw seems like it's too loose so we aren't sure if that is the way to adjust it but it did sound better at idle. We adjusted the screw at the top of the carburator towards the front half of the carburator. It's a flathead screw with a hole in the middle. It may have moved while driving as it was really loose. But the problem is still there. If the choke is not on, the car will stall if not in gear and slowing down or if you're idle and stopped. I have a Haynes manual that's in the mail at the time. Hopefully it'll be here sometime next week, but I was wondering if anyone has had this problem before and/or they have any ideas.
Cheers,
Serge
'86 750L FIRE breather
Cheers,
Serge
