Hi folks,
Ive just test driven and checked out a panda 4x4 and when I got home I phoned the bloked and agreed to buy it.
A few things though - the rocker cover gasket is leaking oil.
I doubt this is a serious problem but where can I get a gasket? (anything I should know about when changing it)
The oil looked ok though.
Im going to change the oil,sparks and oil & air filters as a matter of course so I didnt see this as much of a problem.
There is a little rust appearing on the outside over the rear arches - just a little looked like it would rub away and paint easily.
Two small bubbles on the pasenger door - bottom corners - the begining of the end? -inside looked ok though.
Sills looked fine - both seemed in very good condition generally - a little filler on the back corner - not much though and looked tidy.
Interior was sound but needed a serious clean.
Car was dusty and coverd in leaves - the bloke hadnt pre started it as their was an old spider web over the drivers door etc.
All the electrics worked as did the wipers and wahser jets.
4x4 worked fine although took me a few goes to get it back out of it.
It has 62000 on the clock and lots of old mot's etc. 1988 f reg.
Metalic grey - although the drivers door has clearly been replaced as a few hints of red showing through.
The sunroof things need a serious clean though.
Full bull bars front and back - need to be rubbed down and re painted.
The clutch seeme a little fierce - what are they like normally?
We agreed £200 - as this wise? I dont care - im well exited and cant wait to get started - driving and sorting.
JC
Looking for a 4x4 Panda.
Have a 1992 Eunos Roadster 1.6 (turbocharged - but looks standard)
JC
