theskiprat
I've recently bought a Onyx Firefly kitcar which I believe is based on Panda mechanics. I was wondering if anyone knows if its possible to get Polyflex type bushes to fit the Panda. I'm particularly looking to replace the large rubber rings where the front suspension tie-bar joins on to the engine frame (i assume it bolts to the front valence bodywork on the original Panda). With the extra power of the engine conversion I seem to be getting alot of flex here under heavy accceleration and braking which is affecting the steering a bit.
Also the gearbox seems to be very noisy - it whines alot especially on overrun - is this normal for a panda? The kit has a 1250 punto engine, but the original 1 litre Panda gearbox and I'm wondering if its up to the job.
