New to the board. I have a older gen panda 88 I think.
And it is idling rough. Today I am doing some love and care.
So a couple of things.
I changed the spark plugs and the oil. When I took off the green carb cover I had some pooling oil around the carb and on the bottom of the plastic cover.
The spark plugs had a bunch of build up on them but I do not know when they where changed last.
So the idle problem. When I start i need to have the choke pulled and accel floored. Sometimes it starts rough but almost always takes off quickly. After it is started I can kill the choke after a couple of min as long as I am driving. If I am going to need to stop I need rev a bit then pull the choke back out a bit to keep the revs up. If I do not do this it just sputters and dies. If it does I need to completely floor it and keep the choke off to start it back up.
Any suggestions?
Any suggestions?
