General Petrol tank straps
Panzer
Anyone changed the tank straps on an omega suspension Panda Classic. Tank straps have rotted can't get at front strap bolt, it looks like I need to drop the whole Omega suspension front mount! Bright ideas gratefully accepted.
It can be done with the rear axle in place. I jacked the back of the car on axle stands and used a ?13mm swan neck ring spanner. If you have already removed the other bolts you may end up with the tank falling on you:eek:
I'm off to Halfords to see what special 13mm special weapon I can find. Thanks for the replies.
