I am the owner of a '92 Panda 1000 fire with 201,100km on the meter!!!! (that's about 125,000 miles!!!!).
With the gear put in neutral and the engine still cold(in the morning), the revs are gradually dropping to the point where the engine finally stops. I must push the gas pedal all the time in order to prevent the engine to loose revs (something very annoying especially when you are stopped at red lights) . This happens up to the point where the engine warms up. From that point everything seems to work just fine. Yesterday I covered about 50 km with no problems whatsoever, even though it didn't start normally early in the morning.
My mechanic replaced the automatic choke valve on the exhaust manifold but the problem persists.
Does anyone have any idea what else may be wrong?I know that there is a gas solenoid that arranges the engine's gas feed. Do you think that replacing it will do any good?What about the lamda ("λ" as it is in greek) sensor on the exhaust?Does it affect the "cold" running of the engine?
Thanks, in advance, for your help!
All suggestions are welcomed!
