I've given him the once over and overall he's in pretty good shape as stands, however he's pi$$ing fuel like an incontanant grannie from the tank out fuel pipe. When I removed the cover a jet of fuel 3' high shot into the air. The top of the tank where the In and out fuel pipes are held in place with a clamp is broken so the pipes are not being held firmly in place but are not leaking although I need a new tank unit to replace it as it's unsafe as it stands. I'm also supprised that he hasn't gone in flames as petrol covered all of the electrical wires.
The internal metal gear selecter lever is also broken so if anyone has a lever and cover with grub screw I would be eternally gratefull.
As said it's not bad and easilly fixed and he will look as good as when I first prepared him so don't worry those who await to find out if they have won.
If anyone has those bits can they get intouch urgently thank you.
