I've got your SPI scheme...I needed it before to fit rev counter (still not working
Did you try and fit that to the Panda your now fitting this engine to, or another out of interest
My 16V engine was from P reg Punto and there was no immobiliser (so I hope there shouldn't be problem to start engine
Oh dear, all UK 1242 16v mk1 punto's have an immobiliser ecu as standard. If you are lucky someone has had this one modified to run without the code-box and key.
Yes I tried to fit rev counter to my Selecta. New engine will go to either Selecta one with manual gearbox or to other one in good condition with oryginal manual gear box.Did you try and fit that to the Panda your now fitting this engine to, or another out of interest
hmm I hope you're not right...I asked owner and he said that there was no immobiliser but he could be wrong his key looked normal.Oh dear, all UK 1242 16v mk1 punto's have an immobiliser ecu as standard. If you are lucky someone has had this one modified to run without the code-box and key.
Whoops
As I say, hopefully lilpip will venture over, and be able to help with things
Do you know how to check if there is immobiliser in Punto, there is still chance to back there and get key and some device....
Is there any chance to start engine if there is no right device?
And where is it fitted and how it looks like??
Thanks fot it
Thanks for popping over lilpip
Thank you. I'll email guy who sold me engine and see....if I'm right I also need key (are all same type or I need green/blue/red? ) I think he had green in ignition...there is no AKU now so he/I can't see code light
Thanks again
Jakub
my other email is [email protected] (I'm not sure about max file size)
Whos Putting An Alfav6 In One?!!
I want pics!!not me
but it's truenot me
Wooooahh Wait A Minute!!
hi
anybody knows which fuel pipe is for incoming fuel (IN) and which one is outcoming (OUT)
in 1242 16V Punto engine (MKI)
Thank you!!
