Technical How to fit a 16v Fire engine in a Panda
should i put a live to 1 side of the festoon bulb and the blue/white to the other side?
want that mean a 12v currant will run through the blue/white wire blowing toe code box? plus were do i watch the vid you made thanks
found the video on youtube nice 1 for that mate **** hot:slayer::slayer: il do everthing like what you have it like just to see if it starts tidy it all up after.
(y)
alright mate iv gone and tryed everything you have told me and what is happening is the light is flashing and when i turn the key the light is going off instantly not staying on for 1 second like it should???? any ideas thanks
GOOD GUIDE MATEE !!!
im undergoing a similar project.
for now all i can say is
a MASSIVE thanks to Damon for help all round.
and especially help on wiring !!!! :) 😋 :slayer: :worship:
and i have some info too...
making the mounts is NOT easy.
i took me nearly a day to make both the gearbox mounts.
there is no room on the wing mount to hang the box off it.
you have you change it to upward and going down either side of the box.
i will know more when she is driving.
the gearlink was ok to make ,made alot easyer by welding.
its no direct fit, and the main rod and small lever need changing in length.
and the actual axle off the gear stick to the bulkhead needs straightening in the vice. cos its quite curvy.
currently im making a full 2" exhaust with one good sports backbox.
i will know more soon..
aran.
Yep great information there ,done same
