Martiny10
Member
- Nov 10, 2003
- 292
- 60
As the odometer read 50,001 miles my thoughts last week turned to changing the timing belt.
Getting the belt was easy and after speaking to the FIAT mechanic at my local dealer I decided not to bother getting a new bearing. So for a total outlay of £11 I was looking forward to a painless job. Especially as the Carb FIRE 999CC is a 'safe' engine.
When I lined up the cam shaft sprocket with the timing mark, the crankshaft sprocket did not line up with its timing mark. It was about 1 tooth out.
So I decided that it would be a good idea to 'reset' the crankshaft and turned it so that it lined up.
The engine started and sounded OK, so I put the car back together and went for a spin.
So here's the problem:
The car pinks more than it used to - can I get away with adjusting the distributor or is it a symptom of a bigger problem?
Regards,
Martin
Fix It Again Tony!
Regards,
Martin
Fix It Again Tony!
