I'm fitting a punto 1.1 fire into a panda. After looking over the engine it seems it will transplant fine apart from the punto engine has nowhere to connect the pandas mechanical fuel pump.
Obviously the engine was fuel injection but I remember reading that at least one person on here managed to fit a fire 1.1 engine into a panda running with a carburetor and presumably mechanical fuel pump?
The only options i have come up with are either bodging in an electric fuel pump of some kind or swapping the whole small end with one from a older 999 fire. but i worry if a 999 cam head will work correctly with a 1.1 :/
Suggestions chaps?
Suggestions chaps?
