Thread Tools
Old 11-07-2007   #1
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Electronic Ignition
Can anyone with the electronic ign unit attached to the side of the distributor please let me know what No's are stamped on the distributor next to the module and the year of manufacture if it's original.
The No on the Sisley is SP101C, I tried to replace it with a newer unit with the numbers SP101A. Two things happened, firstly the distributor would not adjust to the 15 deg BTDC as the adjusting holes would not let it rotate far enough, Secondly when I replaced just the module to see what effect it had the engine died as soon as it started to get warm. I let the engine cool and again it started no problem but as soon as it got warm again the engine spluttered to a halt. I then put on the original module and it was no problem at all?
The reason for changing it is there is a very slight hesitation when driving at a constant speed between 20 to 40 mph, when accelerating or at motorway speed or when the engine is at idle there is no problem what so ever. It is as said hardly noticeable but as always I know it's there so want it as perfect as I can make it.
Anyway trying to find out what units were fitted to what year and what differences there are in the unit's?
Thanks lightweightmick thanked for this post
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is offline Reply With Quote Quote
Old 11-07-2007   #2
Re: Electronic Ignition
Hello Alan.
Do not have a 4x4 so cannot draw direct comparison but I have two electronic type distributors.
This one came from an Uno 45, F reg. SE101A-7B and no visible markings on the electronic unit.
This one from an Uno 45, E reg. SE101A-3B and on the underside of the electronic unit, 263 D
These were both the original fitment to the vehicles though I am unable to see any dates of manufacture.
The part number would indicate that the electronic unit is the same one across all the Marelli distributors. Both the setups mentioned above are now fitted on Panda's and no problems ( such as you describe ) were experienced.
Hope this helps.
Rgds.
petel is offline Reply With Quote Quote
Old 11-07-2007   #3
taffy git
gaz.d's Avatar
Trader Rating: 2
gaz.d has donated!
Where do I look?
Gaz
FIAT No More
gaz.d is offline Reply With Quote Quote
Old 11-07-2007   #4
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
On the very top of the distributor Gaz next to the holding nut.
Pete you say these are fitted on your panda's with no problems the panda fire engines are all 2 deg BTDC without vacum or 15 deg BTDC with vacum, which is exactly the same setting, but the SE101A-3b will not set anywhere close to this maybe it's just faulty?
The other problem I was facing was the modules and again I bought brand new from ebay. But the fault of the car dying after becomming warm is consistant when I change them over, when I use the original I have no problems at all other than this slight hesitation
Old 11-07-2007   #5
Nice to see the old pandas going as a suggestion Fire engine will run with jumped cam belts! with out doing damage also the bob wieghts in the distributer can sieze or the spring breaks, check the simple things first before spending out on more ignition modules or dissy, hope this helps
richmal is offline Reply With Quote Quote
Old 11-07-2007   #6
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
I got three spares and they all look perfect but something between the dizzy & module isn't working correctly.
Old 11-07-2007   #7
taffy git
gaz.d's Avatar
Trader Rating: 2
gaz.d has donated!
Mine is SE1010 -> OE
Hope it helps
Gaz
FIAT No More
Old 12-07-2007   #8
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Gaz it will be SE101C, what year is your Sisley? I forgot
On the same note I went back out and changed a mixture of Ign units & Module's. The first Ign unit a SE101A (which is brand new) with a known working module wouldn't adjust beyond 10 deg BTDC with vacum so no use as the setting is as previously mentioned 15 deg BTDC. The second SE101A unit with the same module was knackered the car just wouldn't start.
The SE101C unit I removed I knew was working before I started so know that's ok, I then tried the Second SE101C unit with another module which started to break down within about 2 min. I threw that module and fitted a new one which now appears to be working perfectly after a quick run.
I also cleaned all of the earth points on the hedgehog and the battery -ve lead on the body and engine block as the voltmeter was occasionally spiking showing an earth problem so that may have also been a factor that is now resolved.
Old 12-07-2007   #9
Hello Alan.
Can confirm that the SE101A-3B that I have on one of the Panda's, fitted and works without problem. I have never had any reason to question it.
Rgds.
Old 12-07-2007   #10
taffy git
gaz.d's Avatar
Trader Rating: 2
gaz.d has donated!
Quote Originally Posted by Alan.D View Post
It a 91
Probably is a C under all the muck
Gaz
FIAT No More
Old 12-07-2007   #11
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
Thanks Gaz.
Pete they must have been changed from 88-89 from the A to C, wonder what happened to B
Strange that the units looked new but both were useless, the two C units are dirty looking and from the current 89 and previous 91 Sisley but work well. I wonder if the change was due to the larger camshaft on the 4x4's?
Old 29-01-2010   #12
I have an '89 1000s which has non-electronic contacts. I have just purchased an electronic dizzy from ebay. On the mechanical points dis there is only one LT wire that goes from Dizzy to coil. On electronic there are two a Red and a Green. Am I right in assuming that the red is a power supply and the green is to the coil. And when hooking these up it will all work OK. By the way the serial no. is SE101A 7L.
don.gilkes is offline Reply With Quote Quote
Old 30-01-2010   #13
lightweightmick has donated!
If it helps mine's SE101A -> 6J (on a 1990) - looks like 6J but it's too bloody cold out there to hang around!
Though I've no experience of the distributor, is it not possible to adapt (by rotating) the pick-up heads on the inside?
(thanks for those locks again btw )
Ellen - '87 Ducato 2.5D Elddis Autoking 630CK
Viv - '02 Seicento 1.1 SX
Billy - '02 Seicento 1.1 SX
lightweightmick is offline Reply With Quote Quote
Old 04-02-2010   #14
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
I should hit the Uno section for that, if it's the breakerless system I think you mean, pretty much all the carb'd fire Unos came with that and very few of the Pandas.
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 05-02-2010   #15
I understand the Sisley's had an electronic set-up. I have bought the Dizzy off ebay and want it to work on the 1000s. So I have carb engine with breaker style ignition coil
Thread Tools
(T) Electronic Ignition Conversion 852421 X1/9 5 01-04-2008 17:03
(G) Ignition Wiring.... NovaVan Panda (Classic) 3 04-06-2007 18:20
(T) no spark in electronic ignition samantha Bravo / Brava 2 26-02-2006 15:51
(G) Electronic Ignition Thingy Sprox Panda (Classic) 39 22-02-2006 11:46
(G) uno mk1 ignition switch wiring coolhand_mike Uno 0 07-10-2004 00:58
