toecutter
I've looked at the chart that was posted a few weeks back- I get the bit about making sure the PCd, centre bore size and offset are the same, but what I'm looking for are tried and tested (known)suggestions for slightly larger tyres, or rims and tyres.
The reason, slightly higher final drive ratiobetter fuel consumption at highway speeds. I've got a cl 1000, 4 speed. 1st is very low, and 4th often too low- I get fed up with the engine whine over 55mph.
I understand the speedo will read artifically low, and braking will be lessened (bigger disk to be stopped), but I drive carefully.
Ideas?
Justin
Ideas?
Justin
