| Thread Tools |
![]() | #1 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | ![]() Hi, Just thought I'd ask if anyone can tell me where I can buy new headlamps for my 1972 Fiat 128 Saloon. It has round headlamps. I need British spec lamps not european ones. Anyone know an English website or company that I can order some through? I live in New Zealand and these parts are as scarce as hens teeth. cheers Alister
![]() | #2 | ||
Join Date: Mar 2004 Location: harrogate, United Kingdom.
Posts: 151 Thanks: 0 Trader Rating: 0 | Re: Fiat 128 Headlamps Hi Alister, I will make a few enquiries for you over the next few days. I have a few good 128 contacts who may be able to help. Chris
![]() | #3 | ||
Posts: 151 Thanks: 0 Trader Rating: 0 | Re: Fiat 128 Headlamps The following reply was sent to me which may be of interst to ya: The 128 Saloon and 128 Special had different headlamps. They looked the same but different lens patterns and the Special had Halogen bulbs. Fitting and shape-wise they are the same as 127 Mk1/Mk2 and Fiat 126 (as well as Maserati Biturbo). The easiest to get hold of are the ones for the 126 which are still available new from most dealers and good motor factors as they are made in Poland. Unlike the 128, the 126 had a sidelight bulb in the headlamp but they don't have to be connected for the 128. I'd suggest getting a pair of 126 headlamps so the lens patterns match. I am sure Ricambio can still supply them and would send them to New Zealand as well. Regards, Chris
![]() | #4 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: Fiat 128 Headlamps Hi Chris, Thanks for the info, My 128 is a 1972 saloon with round headlamps (series 1) like the Rallye. The Fiat 126 and 127 have rectangular ones and so does the 128CL etc in the English market. The 126 / 127 headlamps won't fit in the grill. I'll keep looking. Thanks for your help.
![]() | #5 | ||
![]() | Re: Fiat 128 Headlamps Hi Chris, Thanks for the info, My 128 is a 1972 saloon with round headlamps (series 1) like the Rallye. The Fiat 126 and 127 have rectangular ones and so does the 128CL etc in the English market. The 126 / 127 headlamps won't fit in the grill. I'll keep looking. Thanks for your help. http://www.classic-car-accessories.c..._LIGHTS_5.html Andy. ![]()
![]() | #6 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: Fiat 128 Headlamps Hi Andy, That's just what I needed!!! thanks. Over here all the replacement remanufactured ones seem to be no longer available.
![]() | #7 | ||
![]() | #8 | ||
Posts: 140 Thanks: 3 Trader Rating: 0 ![]() | Re: Fiat 128 Headlamps Alister, the 128 sedan headlamps are sort of peculiar, as the mounting lugs on the rear are unique to the model, and you also need a provision for a park lamp in the headlamp. you can make new mounting assemblies and use a standard H4 type 7inch light, but thats a bit of work, but worth it if you want to use decent lights like Hella's or Marchals. If your stuck and want some original style Carello or SIEM headlights to suit assymetric globes, give me a PM and I'll forward my dads work phone number, I know he has genuine items in stock. SteveC
![]() | #9 | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | Re: Fiat 128 Headlamps Hi, I sell these, with or without the base. But I'm not sure how the British specs are different from the Euro specs. Just let me know I maybe able to help. Tico ![]()
![]() | #10 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 ![]() | Re: Fiat 128 Headlamps Hi Tico, NZ is righthand drive like the UK. Europe is lefthand drive like the US. The headlamps on Euro spec cars need to be altered to light up the lefthand side of the road as the glass lens is cut differently (so I am told). This may or may not be correct. If your Euro spec headlamps can be used in the UK without modification and still pass the vehicle testing stations test then PM me ![]() cheers Alister
Thread Tools | |
![]() | respect | Stilo | 54 | 09-10-2006 21:15 |
Ten of the Best? | alainax | Leisure Lounge | 16 | 04-08-2006 02:03 |
FAO Bushboy | Steven | Leisure Lounge | 13 | 25-07-2006 11:41 |
![]() | ivantate | Cinquecento / Seicento | 19 | 25-01-2006 19:00 |
![]() | Fiatawy | Other Fiats | 6 | 10-08-2005 12:30 |
