Old 19-02-2003   #1
Rust never sleeps
fiatritmo has donated!
Norway
Fast idle on '87 Ritmo/Strada
Hello!
I have a 1987 Fiat Ritmo (Strada) 85S, with the 1498 SOHC engine (149.A5.000, also found in some Regatas). It has a Weber carburettor (32/34 TLDE/150, I think) with a manual choke.
The problem is, when I start the car when the engine is cold, the engine runs at around 2000-2600 RPM. It does so for several minutes (ranging from 2-10 minutes) before it reaches "normal" idling speed (somewhere around 800-1000 RPM, I think). This seems to coincide with the engine temperature reaching around 50 degrees Celsius.
Should the engine really fast-idle at this high RPM and for this amount of time? And if not, what might be the problem and how do I fix it? :)
Might be worth mentioning that the engine idles normally when I start it when it's warm.
fiatritmo is offline Reply With Quote Quote
Old 05-12-2003   #2
hi
I think you need to check fast idle control on your choke mechanism!
barry is offline Reply With Quote Quote
Old 13-02-2004   #3
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
It's propably just weber's automatic to get the car running during winter. Nothing to worry about. Do you use the manual choke in addition, or is it just running at 2000 rpm during startup? We had the exact same car earlier. Fell to pieces litteraly: No clutch, shifted gears on engine speed. Hand brake ripped off. Exhaust fell off in one piece - incredible sound afterwards. Windows just broke when jacking car. Brake fluid pumped out of both rear cylinders. Wipers, lights, heater worked occasionally, fixed after welding in some short circuits in the fuse box. But the engine!!! Incredible. It was impossible to destroy, and we tried!
So don't worry about the idling.
Morten.
abarth alloys, steering wheel. inter alloy lowering. phoenix gold audio. refurnish.
projects: induction. seats. exhaust. tinting.
Morty Mort is offline Reply With Quote Quote
(G) Another Idle Problem - Please help Soj Uno 1 26-07-2005 15:36
(T) [Tipo 1.6 ie 94] Injection light and idle Malex Tipo (Classic) 1 28-07-2004 21:18
(G) erratic idle Throttle Body nightmare Stewie Uno 0 03-06-2004 01:52
(T) erratic fast idle Fergus Punto (Mk2/2b) 3 19-10-2003 15:42
Fast idle on '87 Ritmo/Strada fiatritmo Lets Talk FIAT 2 24-02-2003 21:22
