Hello!
I have a 1987 Fiat Ritmo (Strada) 85S, with the 1498 SOHC engine (149.A5.000, also found in some Regatas). It has a Weber carburettor (32/34 TLDE/150, I think) with a manual choke.
The problem is, when I start the car when the engine is cold, the engine runs at around 2000-2600 RPM. It does so for several minutes (ranging from 2-10 minutes) before it reaches "normal" idling speed (somewhere around 800-1000 RPM, I think). This seems to coincide with the engine temperature reaching around 50 degrees Celsius.
Should the engine really fast-idle at this high RPM and for this amount of time? And if not, what might be the problem and how do I fix it?
Might be worth mentioning that the engine idles normally when I start it when it's warm.
