Thread Tools
Old 22-11-2006   #1
Spain
Diferences between Weber DMTE/DMTR
Hello:
My FIAT 128 Sport Coupe has a Weber DMTE, but I know originally was an DMTR .
Anyone knows the difference?
Thank you!
miatapep is offline Reply With Quote Quote
Old 28-11-2006   #2
Trader Rating: 1
alexGS has donated!
New Zealand
Re: Diferences between Weber DMTE/DMTR
Yes - I think I know the difference having owned both
The Uno 1116cc and 1301cc after 1987-ish came with a DMTE carburettor. The 'E' stands for 'Emissions' (in effect) since there is a fuel-cutoff valve incorporated but also an idle-up device (on later 1301cc versions) that permits the manual choke to be pushed in sooner. This idle-up device is a square diaphragm-thing that pulls on the throttle at the back of the carb.
Another difference is that the idle system has a large thumbscrew on the older DMTR, which is a bypass adjustment. The DMTE just has the usual screw that pushes the throttle open.
Practically though, there are jetting and venturi differences. Assuming that you have a 1301cc-version of the carb, here they are:
___________________DMTR______DMTE
Barrel sizes_________32/32______30/32
Venturi sizes________22/22______19/23
Primary Idle jet______0.50_______0.45
Primary Main jet_____1.05_______0.90
Primary Air Corrector_1.95_______2.20
Secondary Idle jet___0.70_______0.70
Secondary Main jet__1.15_______0.97
Secondary Air C'tor__1.90_______1.75
Obviously there are other differences but these are the main ones... and as you can see, the DMTE gives you less fuel and more air, basically. It's designed for the 'soft' cam of the Uno that doesn't allow the engine to develop as much power at high revs, but gives reasonable torque (a little more than the 128) at lower revs.
Hope this helps!
Cheers,
-Alex
'15 Giulietta 1.4MA, 14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 22-07-2016   #3
Indonesia
This thread really informed me well.
How about Solex C 30/32 cic that also used by 128? Is it good enough to installed on Uno70SL?
cudunk is offline Reply With Quote Quote
Old 22-07-2016   #4
varesecrazy has donated!
Thanks alexGS thanked for this post
Old 22-07-2016   #5
Trader Rating: 1
alexGS has donated!
New Zealand
I don't know anything like as much as I did six years ago
The Solex option was always jetted and sized equivalent to the Weber (in the same application), so yes, it will work, but it will be different to the Solex for the Uno in similar ways to described above.
I think in choosing which carburettor to use, the decision now comes down to which has the least throttle shaft wear, missing fixings, etc.
-Alex
Thanks cudunk thanked for this post
Thread Tools
(G) weber carb info panda racer Panda (Classic) 2 17-03-2017 17:08
(T) Help with Weber 32/34 settings yoothoos Uno 4 10-08-2006 17:19
(G) Weber FLT jet sizes zucherro Panda (Classic) 1 13-05-2005 20:11
(G) Still problems with Weber DMTE jaba Uno 0 25-05-2004 18:22
