| Thread Tools |
![]() | #1 | ||
Posts: 4 Thanks: 0 Trader Rating: 0 ![]() | Gearbox Fiat 128 Sport Coupè 1100S (1973) Hello!. I'm from Spain, My 128 it's fitted with a 1300 Regata engine with the 128 4speed gearbox. Now I have a trouble with it. I'm thinking about to put a 5 speed gearbox from a Regata or Uno. Do you think , that it's easy to do?. Must be to do some extra work or other modifications? Thank you!
![]() | #2 |
Posts: 11 Thanks: 0 Trader Rating: 0 ![]() | Re: Gearbox Fiat 128 Sport Coupè 1100S (1973) Here in argentina its very common to change the transmition but you must now that to do.
__________________ [B][CENTER][COLOR="MediumTurquoise"]Powered[/COLOR] by [COLOR="Blue"]Fiat[/COLOR] [COLOR="Red"]IDEA[/COLOR] 1.8 HLX 110HP [/CENTER][/B] |
![]() | #3 | ||
Join Date: Mar 2004 Location: harrogate, United Kingdom.
Posts: 151 Thanks: 0 Trader Rating: 0 | Re: Gearbox Fiat 128 Sport Coupè 1100S (1973) I have had a 5 speed box fitted in my previous 128. I used a strada 75 5 speed box, and was able to use the standard 128 driveshafts with it. It also cleared the inner wing ok, although I have heard rumours in the past that some people have had to modify the inner wing chassis leg to get extra clearance. Any strada sohc box should fit easily, however, I am not a mechanic and did not fit it personally. The only negative thing I do remember was that when using the 128 gear linkage, (which is only designed for 4 speed of course), you have to push the gear stick down before moving across and forward to get 5th , but I soon got used to that! (Similar movement used for selecting reverse on 128) If you are struggling, I will make contact with the guy who did, and will let you know any important do's and don'ts Regards, Chris ps, very nice coupe by the way!!
Thread Tools | |
Car & variant in your mini profile | Goldie Punto | Site Ideas | 33 | 20-03-2007 13:53 |
![]() | ahmad_abdallah | Other Fiats | 1 | 19-05-2006 11:17 |
