![]() | #1 | ||
Posts: 4 Thanks: 1 Trader Rating: 0 ![]() | 1950 Topolino Gearbox 500C Hi I have the gear box apart on my Topolino and can't see how I think it is 3 gear on the output shaft comes off there is a ring with a small notch in it but it not a normal circlip and I can't see how you undo it Does any one have a manual they can scan a couple of the gearbox pages for me the rest of the gearbox is straight forward and no problem Regards Ray Hudson
![]() | #2 | ||
Posts: 27,876 Thanks: 1092 Trader Rating: 0 ![]() | Hi I have the gear box apart on my Topolino and can't see how I think it is 3 gear on the output shaft comes off there is a ring with a small notch in it but it not a normal circlip and I can't see how you undo it Does any one have a manual they can scan a couple of the gearbox pages for me the rest of the gearbox is straight forward and no problem Regards Ray Hudson Hi Ray Could you post a couple of photo's ? At least we can see what we are discussing ![]() Charlie
![]() | #3 | ||
Posts: 4 Thanks: 1 Trader Rating: 0 ![]() | Re: 1950 Topolino Gearbox 500C I got it it is third gear and it runs on a bronze bearing which is splined on there is a trick little spring loaded key that has to be pushed back then the front ring turned till the splines line up and it comes off I have found a place that has these bronze bushes and the roller bearing are pretty standard so can get them here so all good thanks any way Regards Ray
500 1950 Topolino 'C' Project | Uno italia | Members Motors | 30 | 25-02-2019 10:14 |
Topolino 1950 topolino | FAMILYGUY56 | Newbie Central | 1 | 30-09-2017 11:59 |
