Technical 1200 coolant temp sensor
kerrywittig
I’m looking for a source or cross reference part to replace the coolant temperature sensor that’s located on the intake manifold of my 1959 1200. It’s a one Wier sensor, made by Venglia, has a number on it of Tp 685, appears to be the original.
Problem is that the terminal has been broken off of it.
Thanks for the tip.
I have soldered a terminal to the existing sensor. I’ll see if that sends a signal to the temp gauge before looking for a new one.
Thank you...
