![]() | #1 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 ![]() | Fiat Ducato 4x4 Hello I have Fiat Ducato 4x4 And after turning left on straight line steering keeps going left And after turning right it stops . steering is as it should be. Can you somehow help with problem ?
![]() | #2 | ||
Posts: 26,490 Thanks: 1019 Trader Rating: 0 ![]() | Re: Fiat Ducato 4x4 Hi ![]() Old question.. Its a stiff joint in the steering.. Probably best to raise front end and disconnet the steering rack to hub joint on one side How stiff to turn the hub? ( You can use the road wheel as leverage) Now turn the steering.. any easier Reinstall joint Then.. Remove opposite joint Make comparisons ![]() Once you know which side is stiff.. investigate further Do let us know what you find ![]() Charlie
![]() | #3 | ||
Posts: 26,490 Thanks: 1019 Trader Rating: 0 ![]() | Hello I have Fiat Ducato 4x4 And after turning left on straight line steering keeps going left And after turning right it stops . steering is as it should be. Can you somehow help with problem ?
![]() | dazautoking790 | Ducato | 1 | 17-01-2017 18:45 |
![]() | russell9401 | Ducato | 6 | 15-10-2016 03:15 |
![]() | The45 | Ducato | 0 | 19-03-2006 12:27 |
Proud owner of a Fiat Ducato Eurotour 4x4... | The45 | Newbie Central | 2 | 09-03-2006 15:55 |
fiat ducato 4x4 minibus | dave | Auction Watch | 3 | 27-01-2004 22:34 |
