hello everybody,
my father has an old autobianchi giardiniera 1977, which stands for more than 10 years in the garage. The last time we drove the car everything worked smoothly. Now I want to use it again. Before I treid to ignite the car i did te folowing:
-changed the oil
-changed the battery
-cleaned the fuel tank and put new fuel
-cleaned the fuel and oil filter
-cleaned the carborator
-changed the spark plugs
-changed the ignition coil
-changed the ignition leads
-changed the distributor rotor
-changed the contact breaker of the dirstributor
-changed the condenser
After I did all of that I tried to ignite it and after a few tries with some longer pause inbetween, the car still won't start. So I checkes that there is a spark between the contact breaker of the distributor and the spark in the spark plugs but still it does not work.
I do not have any idea what I could change or check or do now to make it run again. I would appreciate if you could help me and give me some ideas of what I should do next.
Many thanks in advance.
-changed the oil
