General Seicento sporting lights
Debbie8
Hi. My mum had her lights changed when she moved to France 15years ago. This year it failed its mot as the levelling motors were not fitted. I can't seem to find any anywhere. Any help would be much appreciated.
If it doesn't have levering motor system then the level is set manually.
Did it fail control technic on beam too high or too low?
Has the car had a bump on the front?
I'm wondering how it passed for 14 years without levelling motors?
The headlamps fitted should have levelling motors but the bloke who fitted them fixed them in place. I've no idea what happened to the original motors. What about a stilo motor? . Do you think they could use them.?
Ah sorry just saw post about fixing in place
It is likely the basic setting of aim is part of motor
So yes looks like you need replacement head lights with motors
EBay.fr?
Ah I think there is a problem here.
Just looked at fiatdalys on line catalogue.
Appears that the adjustable headlights were hydraulically adjusted , electrically adjusted or just manual adjust.
If you can find a headlamp with manual adjuster . Then that will work just needs fitting and aiming.
They were definitely electric jackwhoo but thank you for your help
https://m.autodoc.co.uk/abakus/7760385
Swipe left to 2nd and third pic to see manual adjuster not yet fitted to head light.
The head light in this link fits hydraulic adjust, electric adjust or use the manual adjuster and use head light as is.
Something like this would get your mum's car through it's C T
And appears to be a cheap solution
I've ordered a pair of cheap punto motors for them. Half the problem is I'm in the UK trying to sort this out and I'm getting all the info third party. But thank you so much for all your help. It is truly appreciated.
Good on you for doing this for your mum, I wonder if she thinks it is easy for you?
If the punto motors.
Someone is going to have fun trying to fit the adjuster motors to headlamps that have been fixed in place! Luckily that will be happening in France:)
