Well, finally, after a ridiculous amount of effort, I removed the old, broken steering wheel. We are obviously in total lockdown here so had to make a puller tool (not strong enough) and a second puller tool (just strong enough and no more) and it finally came with an almighty bang.
I can't get the self cancelling indicators to work though. The ring with the hole in it just spins and only very occasionally catches so I'm assuming some sort of adjustment is required.
New 128SL wheel fitted and, if we ever get out of lockdown, I reckon it'll be nicer to use.
Also my mechanic fitted a water temp gauge and my brother in-law and I made a new dash panel as the original one had been cut to fit a tiny speaker and looked awful. You may notice the high temp reading which is not right. So we have a new Celsius gauge on order.
Hi Andrew,
Thanks for the pics, the 'new' steering wheel looks great.
Yeah, those st. wheels can be difficult to remove, sometimes :bang:
There are proper st. wheel removal tools but I never had one - if my trick of manually rocking the wheel failed, I loosened the centre nut a few turns, placed a length of 10mm flat bar across the wheel spokes with a socket as a spacer underneath bearing on the nut, then squeezed the bar towards the wheel using 2 large G clamps, (the reason for not removing the nut is to prevent the wheel hitting you in the face if it was on very tight).
The ring just spins freely unless you move the indicator stalk to the left or right, underneath are 2 little plastic catches (one for left turn, one for right turn) that pop up and iirc get caught by the ring when it is turned by the steering wheel. I'm sure you'll figure out how it works by having a good look at the indicator switch/stalk unit. Sometimes the little plastic catches get broken, there's also little springs on each that allow the plastic catch to move down out of the way if e.g. you steer right with the indicator stalk set to indicate right and vice-versa. The only adjustment is the gap between the rear of the st. wheel and the ring you mentioned, this is adjusted by loosening the clamp at the bottom of the column switch assembly (I mentioned this in an earlier post). The column switch assembly needs to be adjusted so that the little pin on the rear of the st. wheel engages with the hole in the ring - so that the ring moves in unison with the st. wheel. I can't remember with certainty, but it might be this st. wheel pin that actually cancels the indicators?
Nice job on the dash panel
It's probably a very good idea to have a water temperature gauge on a 128. If I might make a suggestion - whenever I've fitted accessory gauges, I try to angle them towards the driver if possible. You might be able to cut a short length of black pvc? plumbing pipe at an angle to fit between the gauge and the dash panel i.e. straight cut end fits against the gauge, angled cut against the dash panel, might have to slightly 'ovalise' the dash panel hole to suit.
Great to see you're making progress. Over here (Ireland) we're in lockdown also, everything (car parts wise) is shut - fortunately, I'm a bit of a hoarder
or there'd be no work being done.
Al.
