Hello, I'm new here so hi to all!
I bought a imported 1976 127 900cc this time last year. Bought off ebay unseen (madness I know - won't be doing that again).
Anyway, drove the car back from Birmingham to Newcastle at 50 mph and it seemed ok, if a bit gutless, until it blew a spark plug clean out of the head! Close to home by then so got back on 3 cylinders ok. So head off, plug liner in (in fact two as another was about to go), head back on and back up and running. Seemed ok but still gutless and running hot. There was no thermostat when I bought it so have put one in but concerned as to why someone would remove it!?
Sorry for the long story!
Drove it each weekend over the summer but just before the cold weather hibernation she started to stall at junctions. Having woken her up again, the problem is still there but slightly worse - she just won't idle unless the choke is full on, even after warm up. In the garage, the engine sounds rough as though misfiring (still with choke on).
Have changed plugs, leads and condenser as a matter of course and coil because the resistances were way off spec. No difference. Have checked the timing and fuel pump (by using gravity feed) and they seem ok. Haven't changed the dizzy cap yet but am getting good regular sparks from each lead so don't think it's that. Have cleaned the carb and fitted new needle valve and accel pump diaphragm from standard refurb kit etc. No change. Compression readings are a bit all over the place: 145/100/137/117 psi but they were like that after the head went back on well before the problem started. Have seen blogs talking about air leaks but don't really see where they could be, gaskets are all new and no vacuum advance on the carb.
So that's me stuck. Any help or advice would be great.
Many thanks to all who lasted this far!
David
David
