We took the center vents apart and sent them out for chrome...
Every inch of wire is cleaned, inspected, repaired and wrapped again.
The dash switches were taken apart for cleaning and I sent out the bright parts for chrome.
Instead of painting the latches, we remove them, and coat the safety in zinc and clean up the pull latch.
As you can see, we have the original battery cover. However, the batteries you buy for these are too tall, so we had to come up with a solution. The customer wanted a battery tender installed as well, so they could plug it in when they aren't using it for the winter season. My solution was to use a smaller battery, The one i finally purchased was for a motorcycle, it is smaller, but had the same cranking power and it was just small enough to allow me to install the battery tender in the battery box with it and the cover still fit!
Another problem I had to solve was to make a riser pad in the front compartment around the
Battery tray and brake reservoir. This should have one, if I am not
mistaken, (going off of an original 600 I have here). This allows the mat
to lay flat and level with the battery cover.
To do this, I ordered a rubber knee pad and cut it to shape.
