FIAT Auto Specialist Team
Thread Tools
Old 04-09-2014   #1
Australia
Fiat 850 Coupe Hill Climb/Sprint car
This is my Fiat 850 coupe I bought new in 1970. I drove it for 4 years and did all the usual things like get married and had kids. Sold it when we needed more room for the kids. The car stayed local. About 23 years ago when I was towing home a car for my eldest son to rebuild there it was, parked on the side of the road with a for sale sign! Looked a bit sad with plenty of rust but I jumped at it and for $250 I had my old car back with a spare motor and gearbox, spare doors, glass etc.
A few months ago it was announced there will be a motor racing complex built within 20 kays of here! I had already been involved with a club doing hill climbing with a MX5 but now I had some serious motivation to do something with the Fiat. My Fiat was built in 1970 during a period of unrest at the factory and like all the cars built then had poor paint and rust proofing. I had a partial repaint during the warranty period. I decided that the car would not see road service again so I set about building a car for hill climbing using the original motor to ensure it will be Fiat car club friendly! The division I race my Mazda in is up to 1600cc and the Fiat will be doing the same. I have an AMR500 supercharger that will still allow me to race in the under 1600cc classes and my aim is to get the car down to minimum weight. 15 kilos is about 1 hp!
I have gone to a front alloy radiator, wishbone front end and I'm flop moulding epoxy 'glass bonnet, engine covers. Retaining the original windscreen and will have have the rest of the windows in plastic. Lightweight starter motor, Suzuki 750 brake calipers for the front. I have cut out some sheet metal that was not necessary. Weight I have added is the super charger and the half rollcage. The photo below is from a couple of weeks ago. Car is now off the rotisserie. I had to fabricate two new sills and the A pillars both needed some creative metal work and there were a lot of hours spent there!
I will stick up more pictures later.
Likes alexGS, Jayarr liked this post
Porsche 928s, Mercedes E280, Mazda MX5 track car, 1970 Fiat 850 coupe track car.
Ramona is offline Reply With Quote Quote
Old 05-09-2014   #2
Australia
Re: Fiat 850 Coupe Hill Climb/Sprint car
Great story, and love the black and white photo. But OMG that supercharger is huge! Looking forward to future instalments.
Fiat 850 Sport Coupe S2
Alfa Mito QV, Alfa Guilietta (2014)
Jayarr is offline Reply With Quote Quote
Old 05-09-2014   #3
Australia
Quote Originally Posted by Jayarr View Post
No the charger is quite small. I'm estimating about 10psi and aiming for about 75 hp. I have a 1 3/4 inch SU carby and I'm in the throws of making brackets for the unit now although most of my efforts are on the car body. The flat pulley is off a Mitsubishi Verada I think it was. I have machined the original pulley to fit the flat pulley over the top. The bracket is utilizing the water pump bracket and I have a pipe going into the centre for water. 12v water pump up the front.
Likes Jayarr liked this post
Old 05-09-2014   #4
Australia
Had to look twice at the front crank pulley, that's a very neat job integrating the centrifugal filter with the multi rib belt drive. Presume that the alternator will be used as the tensioner for supercharger belt drive, and convert ccw motion to cw.
Cheers.
Old 05-09-2014   #5
Australia
I have an alternator off a Diahatsu that will mount under the charger down low. A belt tensioner will be used using the mounting holes that were used previously for the old alternator on the back of the belt. This is the only way I can think of to clear the rear engine mount. The charger runs either way so its mounted upside down so there is no need to change rotation
Old 05-09-2014   #6
Australia
Front radiator mounting. Original crossmember was rotten so cut it out and made a tube mount for the radiator and fan. The recess in the bulkhead is for a 10 litre alloy fuel tank that fits above and to the rear of the radiator. Coil over wishbone front so have a tube to reinforce the shock towers. Battery box on LHS.
Lots of rust cut out of the front.
Removed the side indicators and bumper bar and welded up the holes.
Half cage welded in and new seat mounts. Coolant pipes will run down the LHS interior
Old 20-09-2014   #7
Great project. I had an 850 Sport CoupÚ (which is what this is) years ago; rust was real pain. My only question would be how long you expect the gearbox to last as the increase in torque must be considerable.
babbo_umbro is offline Reply With Quote Quote
Old 26-09-2014   #8
Australia
Yes rust is a problem. I have been flat out the last few days getting rid of surface rust hidden under the paint on the roof alongside the gutter. I am hoping to have the paint job better than what came from the factory.
The gearbox should be able to handle the torque fine. Drive shafts might be more of a problem. The flexible gearbox connection seems to be more of a failure point and I have mine out out the moment and will through bolt it. Fortunately with modern technology with things like Youtube we can follow people like Fiatnutz and incorporate his modifications and learn from his experiences.
This is slightly off topic but I would be keen to learn more about what gearbox is used with these units. http://www.davrian.net/forum/viewtopic.php?f=4&t=358
Old 28-09-2014   #9
Australia
Looking for the paint code on this car. The original paint is the red in the front "boot". The car was repainted in a brighter red. I think the colour is Monza red 113 but I'm having trouble finding it in the paint companies catalog. Any ideas?
Old 29-09-2014   #10
Australia
Sorry - I don't have access to my records at present. Would have thought paint supply places would colour match for you.
Old 30-09-2014   #11
Australia
The local ones don't have the info and they don't seem too keen on analyzers. I have decided on Ferrari Rosso Monza 311/6. Modern Ferrari red which is pretty close to the old 70's coupe red. The whole car has to be painted anyway.
Old 09-10-2014   #12
Australia
Started flop moulding panels. This is the engine cover after one layup of cloth and epoxy. The scoop is the same as the one I have set up for the front bonnet. Here it is an air intake for the SU carburettor. On the red panel at the back is the mould. I have set it there as an exhaust for the front radiator and a deflector for the single windscreen wiper though its main purpose is as a handhold to lift the bonnet!
The ducktail is 10mm closed cell foam. The lower section of the engine cover is done and will be glued to this piece after it's popped off the mould.
Old 13-11-2014   #13
Australia
More "plastic" bits. Front bonnet trial fitted. Needs to be faired yet and some more edge work with epoxy and carbon 50:50 fibreglass tape. Weighs 1.7 kilos at this stage. Engine cover weighs the same.
Likes Bartpanda liked this post
Old 09-12-2014   #14
Australia
Finally got the doors fitted during the week. After replacing both outer sills and fairly major re construction of the A pillars I was relieved the doors still fitted at all. The gap along the bottom of the doors is perfect.
In the fore ground the rear panel is having the first lay up of fibreglass cloth and epoxy.
Old 09-12-2014   #15
Australia
This is just a photo showing the front cleaned up after welding in the side lights and bumper bar mounts. Second photo shows the front intake for the radiator.
Thanks alexGS thanked for this post
Thread Tools
Uno Liam's Uno turbo Mk1/2 Hill Climb/Road Car frankensteinuno Members Motors 4 01-09-2013 15:33
Prescott hill climb GingerChris Leisure Lounge 0 25-07-2013 12:11
(G) Coupe 20VT Climb hill race - super sound Cernoch Coupe 7 17-05-2008 00:13
harewood speed hill climb dillinger39 Leisure Lounge 4 03-07-2006 10:57
Harewood Hill Climb - 27/03/05 smurfhead Events 0 16-02-2005 23:52
