Hey everyone, newbee here.
I've been a fiat owner for three years now, and have done lots of top end work, but recently removed the engine from the car to investigate some smoke that was blowing out the rocker cover cap. After the removal of the pistons, the problem was easy to find; two of the rings had seized. Pretty small problem really. EXCEPT when I was taking off the rings, the small section of metal that keep the upper two rings separate snapped off . This happened to two pistons!
So I need new pistons. Any ideas of which ones are superior? the pistons that I was running were 65.97 with a small raised section. Should I run flat top pistons, or go for a higher compression piston? I can't seem to find my original ones anywhere. The engine is the standard 903cc, with a DIC30 and nothing except the original parts. Any advice will be much appreciated!
I did try and post pictures, but apparently you need more posts before they are allowed. Perhaps you could access them from my gallery? I'm not sure.
Thanks for looking!
Thanks for looking!
