Old 20-02-2013   #1
Fiat Multipla rear suspension replacement - help!
Help and advice needed please, complete novice at work here!
I have a X reg multipla with the rear wheel leaning in at the top - common fault. We have been told the rear axle needs to be replaced as the suspension is not independant but told by someone else just need to replace the radial arm etc.
Think we are totallyconfused.com!!
Any help on offer would be really appreciated!
md123 is offline Reply With Quote Quote
Old 22-02-2013   #2
Re: Fiat Multipla rear suspension replacement - help!
My m8 at work had same problem, he changed the big bearing on the swing arm, if you can do it yourself or know someone who can do it cheap, he says he got the bearing for 22. But if you take it to a garage they say it needs a full swing arm (just cos its easyer to change the full arm) but the charge 400 ish for the part and fitting per arm!
nellyevogp is offline Reply With Quote Quote
(G) New Fiat MPV. Could it be the replacement for the Multipla ? FiatFleetFamily Multipla 7 18-01-2013 13:39
(T) Multipla rear sub frame mot failure, need replacement stmterrace Multipla 13 07-11-2012 09:31
(T) Rear Suspension Arm Replacement Fivestiles Punto (Mk1) 9 21-03-2011 10:20
(G) Multipla rear suspension bump stops Tooby Multipla 3 18-01-2011 08:50
(T) Multipla rear suspension Justin wilson Multipla 4 22-11-2009 22:21
