FiatGroup
- Feb 17, 2005
- 24
- 6
ZASTAVA 101 (Fiat 128 B1) SINCE 1979
To achieve even more HP it is necessary to put on a 16v head with corresponding pistons, and that would result in unbelieavable 185 HP,.. in short;
Forged pistons, 2 rings c.p.s
Longer rods (uno turbo), lightened too - similar masses - balanced
compression ratio 11:1
head ported to 30.5 mm runners
Valve stems 7 mm
valve springs retaining collars made from SiMg aluminum
intake valves lightened, mushroom made on 3 angle (multiangle machining)
intake valves 40.5 mm
exhaust valves 34.5 mm
]315° camshaft 11.5mm LIFT
Lightened cranckshaft - aerodnamically shaped- polished - balanced - lightened flywheel
4 X 45mm TROTLE BODIES
RP TUNING SPORT LABS MPI Sekvencial WEBER MARELLI I.A.W.
exhaust extractor 4-1
Aluminium adjustable pulley - camshaft and rest
Brakes 257mm front discs (CROMA - TURBO) - steel calipers.
front springs from Fiat 126 (rear)
rear leaf spring from Peugeot Boxer
shocks adjusted for lowered suspension - two way hydrauilc
suspension enhanced by inserting PA6 - Poliamid instead of rubber bushings.
Enhanced and strenghened body
Zeljko Adzic QuarterMile
lamda metar + rpm metar
Mostly all modifications we do by ourselves long under all aftermarket prices.
www.quartermile.ws
This presented veichle is still in building, around engine, few more things are waiting to be made, as well as roll cage install. If there are any other suggestions, feel free to write here or via e-mail.
Valve stems 7 mm
www.quartermile.ws
