126dave
hi, i have found a 600 with this engine fitted, its not a runner.
its bolted up to the 600 box and has the exhaust manifold in place.
its OHV not OHC, theres a spin on oil filter where the fuel pump would have been, the fuel pump is mounted on the timing chain cover, at an angle, as if the engine would have been tilted in the car its from, theres a small water pump mounted on the lower rh side when viewed from behind the car.
on the oil filter side cast into the block is 100GL FIAT
on the other side are these numbers 4387324, 1057, 7D22,
does anyone have any idea what this is? a 127 903cc block maybe?.....
thanks.....
thanks.....
