danielsydney
Member
Hi just thought Id ask what is the recomended oil in the Regata 85S Automatic please?
Fiat engines do not usually like thin oils. Go for a 15w/40 or 15w/50 semi synthetic. All leading brands are good, so not to worry there.Hi just thought Id ask what is the recomended oil in the Regata 85S Automatic please?
Halfords oils are made or were made by Shell, so see if they have any oils on offer.
Andy.
Its been so long since i checked the oil it should be down when the car is cold right?
That's right it is best to check when cold. You should check the oil regularly, even on newer cars. The older Fiat engine did like to leak at least a little bit of oil at times, that's my experience anyway, so regular checking was a must.
We used to run simple 20W/50 mineral oil on our Fiat's. I used to use Agip, I think my dad used, Shell. As Sumplug said, it best not use too thin oils. 15w/40 or 15w/50 semi synthetic is what seems to be recommended these days looking at various websites.
From memory oil change intervals are 6 months/10000km's, but I used to work to 6 months/5000km's
Troy.
Troy what do you make of this Selenia oil that Fiat in Australia is now recommending to new Fiats?
Bearing in mind Australias a hot place (we use 15/40 in the UK where we face sub zero temperatures for a month of the year, something Australians dont have to worry about!) & I`m assuming yours has done over 100,000 miles(Australia`s a big place & mileages usually reflect that), I`d go for a semi synthetic 20/50 to reduce oil consumption.
don't use anything below 15w.
Cars in Australia are liquid cooled for sure, so they use a thermostat, and by doing so they run at EXACTLY the same operating temperatures like almost any other part of the world ( except maybe the north and south pole.....)
Absolutely no need for a different grade/ weight of oil.....any good quality oil will do, in the weight Fiat advises.
Most of the quote is true, but the most important facts are completely wrong, were did you find it?
I assume it's American, and the USA lubrication market/ conditions are really different from the rest of the world, I'm afraid.
And cooling is not important, pardon me, but your quote is full of temperature facts....???
Would be interesting to start a discussion with the author. ( well, on second thoughts, it's not....)
Well, you were still at school, while I was working on my motorcycles....
And..... it seems a lot has changed in 20 years...
Anyway, it doesn't matter what the outside temperatures are, any engine will run at operating temperatures around 80-90 C.
And why are you advising to use mineral oil?
After all, ( and you will have learned this 20 years ago) semi- synthetic oil is in fact hydro crack oil, with is top of the line mineral, and nothing synthetic ( in Germany f.i. it's no longer allowed to name an oil semi synthetic, there is no such a thing as semi synthetic, you can name a Fiat semi Ferrari, but it's still a Fiat....).
A lot of misunderstanding here.
All starts below 20C is considered a cold start.
A good quality mineral or hydrocrack oil will not leave any deposits or coating as you call it.
No engine oil, mineral, hydrocrack or synthetic will react with each other, and (black) sludge is created by something completely different.
(I'm sorry, but I got the feeling this discussion is going nowhere, too many misunderstanding, what school did you go to anyway....)
