Re: flywheel strada 85S
I once fitted the 1500cc engine from an automatic strada into my 128 3p. I used the original 128 4 speed gearbox, but when I mated the two together, I had starter motor problems. I had to first remove the torque converter/flywheel and swap for my 1300 flywheel. However, The flywheel did not sit correctly on the end of the crankshaft. In order to solve the problem, I remember having to have a machinist enlarge the flywheel's central hole, as it was slightly too small to fit onto the end of the 1500cc crank. Once this was done, it was fine though. It may be worth bearing in mind that as my engine came from an automatic strada, I can only assume that the same mod is required on the manual version. I would think the crank would be the same. (Just make sure you get a qualified engineer/machinist to do it accurately of course!) The engine revved for england!
