- Feb 14, 2010
- 197
- 40
Won't 'name and shame', as it's likely to get the forum owners into hot water (I believe..... certainly this is the case on other forums I read).
However, it's a word of warning to those with Selespeed type cars....
The car in question is a late Alfa 156 2.0TSpark Selespeed. It's an import registered on a 56 plate, but was built earlier, so came with a TSpark engine and the pre-facelift body. Not that this is important.
Anyway, last November, the gearbox started playing up - wouldn't select anything other than 1,2,R and N.
As it is covered by an aftermarket warranty, I sent it to my local Alfa / Fiat specialist, who diagnosed the fault and recommended a new actuator. (Amongst other things - the airbag light was on, so they quoted a silly price to 'diagnose' the issue, and they wanted to replace some suspension arms - on a car with 29k miles on it which had only passed an MOT with my trusted local mechanic a month earlier.... but that's another story!)
The work was eventually authorised and I finally got to collect my car around 3 weeks after handing it over to them.
Last week, the Selespeed system started leaving a pool of fluid all over my drive, so I did a bit of investigation - removed the battery tray and cowling over the system to have a good look at it. (See photo attached....)
At this point, I realised the unit wasn't just 3 months old at all - so I returned with the car to the specialist, told them of the leak, and raised my concerns about the unit - to be told 'Alfa supply refurbished exchange units'.
Left the car with them and did some research.... Alfa supply brand new boxed units, at a price £600 less than they charged. This was confirmed by a couple of specialists and a main dealer - one specialist charged only £900 for a new one!
At this point, they called me to tell me the bill would be £150 to replace the 'high pressure hose'.... at which point I went what I believe is called 'postal'....
A quick word with Consumer Direct got me all the legal stuff to challenge them..... one letter and an email later, they'd been given 10 days to remove the old unit and replace with a shiny new one.
I believe they must know I've caught them scamming me, as this was agreed to remarkably quickly (within an hour). The car is being collected in the morning.
If anyone really needs to know which Alfa / Fiat specialist to avoid in my area, feel free to message me..... but I'm sure it wouldn't take a genius to work out who it was. (Although, if you do, please don't post it here!)
Just worth a bit of a warning - if you're having something replaced that's buried deep in the grubby bits of the car - make damned well sure you check it really has been replaced with the promised bit ASAP.
