Hello everbody,, any ideas what this clutch problem could be,,,( w reg punto 1242cc petrol) punto started fine,,,i pulled away and found it hard to put in gear ( slight crunching sound) i drove a few hundred yards ,,, turned around and started to drive home,,, then i noticed ,,, when i released the clutch in 1st,, 2nd,, 3rd ,,4th,,, 5th,, even reverse ( reverse light comes on) it would not pull away,,, it seemed to be able to go into gear,,,, without even putting the clutch down ( engine running) it would not stall ,,, could this be down to hydraulics ( slave or master cylinder) there dont seem to be any leaks though,,, any ideas please help ??? HI TO EVERYONE ON THE FORUM MANY THANKS LINDA
