FIAT Auto Specialist Team
Old 5 Days Ago   #1
Thumbs up Newbie needs help
Hi every one, I wonder if any body can help me (because the fiat dealers wantŁ!!!!!!!!!!! just to look at it and God knows how much to fix it ). I am the proud owner of a 2017 1.6 Doblo with the tyre pressure monitoring unavailable notice stuck on. this problem started about 3 months ago and I presumed that a tyre sensor had failed, I didn't like the Cargo Marathon s that were on it so I Bit the bullet and had new tyres and sensors fitted, I then followed the procedure for resetting/reprogramming them to to the tpms module/ecu several attempts and over a hundred miles later it's just the same. After several sessions on the Multiecuscan I've come to the conclusion that the tpms module/ecu is at fault, the trouble is I can't find it on the car and fiat won't tell me where it is. Many thanks in advance and any advice or solution will be much appreciated. This is my third Doblo after a 2004 and a 2009 again many thanks. Dale
Dale flowers is offline Reply With Quote Quote
Old 5 Days Ago   #2
varesecrazy has donated!
Re: Newbie needs help
Hi
SEARCH the tipo..and 500 sections
There have been a few useful threads this year
Old 5 Days Ago   #3
Thumbs up Re: Newbie needs help
Hi, many thanks will do. Dale.
Old 3 Days Ago   #4
Hi to all, I've had a look around the forum but have been unable to find anything about the problem I have with the tpms unavailable on a Doblo, there is plenty of advice for the 500's etc as they have a tpms reset in the menu but unfortunately the Doblo doesn't. Does anybody know where the tpms module/ecu is locatedon the Doblo because I'm now convinced that this is the culprit. I have Multiecuscan if a new unit is needed to connect it etc hopefully it may be a case of cleaning the plug and the terminals thanks to varecrazy for his helpful reply and I look forward to any replies I get. Dale.
P.S tpms warning light on is now an MOT failure .
